My engine hatch release is very tempremental. I have to pull the lever then pull on the engine hatch lid. Get it in the right position and it will open. --- I know it needs to be adjusted - but which way? If I adjust the wrong way how do I open the lid?
Also I have two cables going to my release mechanism -- one is a shielded release cable - the other is a nonshieled cable. I pulled the nonshieled cable out a way and don't know what it does -- anyone know.
Chuck --- Myrtle Beach, SC
The unshielded cable is the emergency release cable. The other end of it should be behind the left taillight. The way I adjust the lock is to lossen the 2 bolts and raise the lock to the top of its travel, then just snug the bolts up a little, close the trunk and see if the lever will open the trunk. It should open up fine but the trunk will be too high. I then press down steadily on the trunk against the lock until the trunk is down completely. Confirm that the trunk opens unassisted and then tighten the 2 bolts.
Make sure that the cable is properly connected to the lock before doing any adjustment.
Edited by 1999Porsche911
