I have a 2008 Cayenne Turbo that came with 295 / 35 R21 107 Y tires and I replaced them with 285 / 35 R22 106 V tires.
It appears that the Speedometer reads about 3 MPH slow (it shows 67 mph and you really going 70 mph).
I went into the main menu where it gives you the option to change tire sizes, but it only goes up to 21"
Is there a way to correct this?
Thanks for the tire caculator info.
I was hoping that someone would know of a company that makes a module that would allow you to add the 22" tire size in the menu.
I know there is a company that makes a module for the PCM so you can do Bluetooth through the PCM and was hoping there was one to correct for the tire size.
it wouldn't be worth the expense
and it's not really a big deal
