Hello,
Can someone tell me the easiest/best way to remove the rear spoiler on a 2004 cayenne to get to the radio antenna so I can place the xm radio fm modulator on the antenna?
Open the rear glass, with that open you can see the 3 TORX screws, take them out and close the glass then carefully lift the top of the spoiler off, its on a neoprene seal so it takes a slight effort to get it started.
My gallery on Rennlist has pictures
Mike
Hello,
  • 3 months later...
i managed to unscrew 2 TORX bolts but third is turning but is not unscrewing (i assume nut is turning inside). I am stuck now any help is appreciated
See if you can start to pry it apart, and unscrew the torx at the same time
a bit risky, but you may have no alternative
tried that, no luck. do i drill through this bolt now? what a pain
