My right front wheel hit a curb as I was rounding a corner... about 20mph... the steeringwheel alignment is off by about 50 degrees and the front end feels really loose... especially when going above 40mph. The car will stay in a straight line but when I "zig zag" it really wonders all over the place... it's a little scary. Any idea of what suspension components might be damaged? Is this going to be a serious repair? If so, is it going to drain my bank account?
--2001 986 Boxster 2.7--
51k mi.
Edited by Goombatz
Yes it's serious. I wouldn't drive it to far to fast. And yes you'll be reamed if you leave it with a dealer. But, aside from parts cost (depending on what you broke), any shop can fix it (unless you bent something that requires a body shop). Have fun.
Regards, PK
Edited by pk2
Take the wheel off and look if you can. There is not all that much under there.
There is a transverse control arm - it is at the bottom, attaches to the aluminum cross member on the inside, and attaches to the wheel carrier with a ball joint.
There is a diagonal control arm - it runs from a front frame attachment point to the transverse control arm.
And there is the tie rod - this is part of the steering rack and attaches to wheel carrier - on the forward edge of the wheel carrier if I remember correctly.
There are other bits and pieces under there, of course, such as drop links, coilovers, etc.
I would look hard at the tie rod. I think that is the mostly likely culprit. Inspect your wheel too - you might have bent the rim. (If you did bend the rim, don't throw it out - send it off to be straightened. Much cheaper.)
I recently did some suspension upgrades on my track dedicated 986S (solid bushings, mounts and bearings plus adjustable coil overs). I replaced one transverse control arm - it was something like $350, and one rear toe adjustor for $75 I think.
I have not priced an outer tie rod, but I would guess $100 ballpark???
Labor is another matter. If you are a competent wrench, and you have the right tools, these pieces can be replaced as DIY. You would need to take it to an alignment shop afterward, obviously.
One important note - I am not sure of the PSM stuff on your model 986, but I know on later models that there is a steering angle sensor in the steering wheel. If you have knocked the alignment out a huge amount, you might get a steering wheel angle sensor error code (CEL). If your model has this feature, you will want to take your car to a shop that can re-calibrate your steering angle sensor with a PST2 type tools when they do the alignment.
Thanks for your valuable input. I'm taking her to the shop tomorrow (certified Porsche mechanic)... I'll let everyone know how it went... wish me luck!
