Have had my '02 non S for almost 4yrs and put about 15000 on it. The brake wear indicator light has just appeared. I'm not too concerned about retaining the wear sensor, the pads that I purchase may or may not be drilled for it and I am fairly good about keeping an eye on things.
How quickly, non-track mileage, should I really worry about changing the pads, and will the indicator light go out if the sensor isn't reattached?
I know that I should just go out and snatch a wheel off and verify for myself the status of the pads but, although I do have covered storage it doesn't have walls around it and it's cold outside. I'm a southerner and we have thin skin. I want to save my outside time for actually replacing the pads. I don't just have to recover from the time spent out in the cold, I also have to recover from the amount of "antifreeze" that it takes to thaw me out. So any help would be greatly appreciated by myself and by the buyer of my antifreeze.
Joe
The factory brakes are awesome and last a long time, around 20.000miles.
yes the indicator light will go out if the sensor is removed.
this might be able to help U.
http://www.renntech.org/forums/index.php?s...hl=brake+sensor
Thanks Juniinc,
Your link was most helpful. I had looked and searched but had found no posting addressing the sensor issues as well as your link.
Once again, Renntech and associates comes through for me. I think that should give a Xmas donation ASAP.
