tht's almost an inch difference in overall diameter and your odometer will read slower than actual speed.
Calculations show that when speedo reads 60 you will actually be going 62.5. I would be mire concerned with the handling since the sidewall is taller.
The only issue I would see is dependent upon your offset. If they are stock wheels you should be fine, less your car being tucked that is.
HTH 295-30-19's
