Front trunk light not working on my '99. Bulb, fuse, and light socket all check out OK (swapped socket with rear trunk). Before I tear into the wiring harness, I'd like to rule out the switch itself.
Anyone know where the "turn on the front trunk light" switch is located? I don't see anything obvious that would trigger the light when opening the trunk.
--- Tom
