my side door window on the left seems kinda erratic, when opening the door sometimes it doesn't nudge down.
i have to tell my friends everytime to open slowly just in case the window doesn't nudge down and clips the sill portion of the hood and chips the glass.
is it a sensor problem?
Chances are it is the micro switch in the door handle. You should
get some help if you run a search for window problems
in this site and the 996 site. I had mine replaced under warrenty.
Paul
