As long you will use the specific Porsche approved rim and tire size for the MY of the car, the speedo remains approx. the same and the end reduction of the gearbox as well.
The aspect ratio is the key. Wider the tire, the lower the aspect ratio must be. Tire Rack has a calculator. As in a 185/70 would plus up to 205/60 to maybe 255/50 etc.
Keeping the diameter the same is the key.
Example:
265/35-18 Take 265mm (the width) x the .35 aspect ratio (the sidewalls) x 2, divided by 25.4 (converts to inches) + the rim diameter = tire diameter
