Can anyone advise me on where the "Control Unit Comfort Systems Rear" is physically located on a 2003 Cayenne Turbo?
I need to access it to troubleshoot a suspect wiring fault.
:thankyou:
As Loren mentioned, but rather 13 ( straight under the rear right window ) sometimes the manual is confusing. Remove the follow trims: rear part of the roof, chrome cover of the hatch lock, right part of the trunk bottom trim ( with the two chrome hooks ), right rear part ( small ) beside the chrome lock cover, trim with the belt upper part, you can pull now the main side trim a little to the middle. The control box socket is mounted with a screw to the car body ( under the control box, you cant see the screw ). Removal of the control box is needed to remove the connectors ( they are on the wrong side as usual ). Success.
