Imagine my dismay at discovering that the little button with the Koni shock icon is not a Sport button! I guess my perceptions of a quicker throttle response and snappier exhaust were all in my head! Good thing my C2S seems just as sporty and noisy without one! Does the true Sport button only come with the "Sport Chrono" option? I AM thankful however, that the PASM on the "Morgan +4" setting IS there when all that oomph and torque comes on line out of a corner! Forgive me: I'm just a newbie.
Sport chrono + have two buttons, one with the shock icon= controls only PASM and one with sport inscription which overrules PASM button, throttle control via DME, brakes and a lot more.
Yeah, after reading all that mouth watering stuff in the manual about what that button does, I ran to look inside my car and alas, no Sport button. Drat. Still love that little green monster though.
Sport Chrono simply adds the "Sport" button which re-maps the throttle and stiffens the PASM. I'm not aware of it doing anything with brakes. It is the least used option I have, as I find the re-mapped throttle somewhat useless (and problematic in autocross applications). And the chrono thing is so complicated I have no interest in trying to use it. In my opinion, you're not missing anything by not having the "sport" button.
With my tiptronic the sport button speeds shortens the
up and down shifting time. It also some how makes the motor
louder. This is real good at the track. Not sure
if you need it around town.
Paul
. . . It also some how makes the motor
Paul
I read/heard somewhere, that the Sport setting also bypasses a coupla baffles in the muffler, or maybe it's on the intake side.
From the Porsche Technik Book:
"Effects of the Sport Chrono function on the Motronic
The optionally available Sport Chrono Package notably increases driving pleasure and the vehicle’s performance. The engine is also affected when the Sport Chrono button is activated.
The following features are initiated:
More sporty load cycle behaviour
When the Sport Chrono function is selected, the transfers between acceleration and deceleration become sportier. This means that injection and ignition are switched on and off more directly when accelerating and particularly when decelerating, resulting in a more spontaneous and dynamic load cycle.
More abrupt engine speed cut-off
To increase driving comfort a ’gentle’ cut-off is generally used when accelerating and reaching the engine speed cut-off setting. In the process the throttle is continuously closed when approaching the limit range for speed. The Sport Chrono function facilitates additional acceleration potential through the use of an abrupt engine speed cut-off by switching off individual cylinders (injection and ignition) in a rotating fashion just shortly before the engine speed limit. The perceptible limit of acceleration lets the driver know if an upshift is executed too late. This allows the driver to learn how to identify the optimum shift point with more accuracy and to take fuller advantage of the engine’s potential for acceleration.
When the Sport Chrono button is pressed, the abrupt cut-off is active in 1st to 5th gears for the manual gearbox (without Sport Chrono function only in 1st and 2nd gears) and in the manual gate “M” for Tiptronic transmission.
More dynamic accelerator pedal characteristic
The electronic accelerator pedal (electronic throttle) has been used on the 911 Carrera models since model year 2000. With this system, the accelerator pedal position is converted into electrical signals via potentiometers and forwarded as a control signal to the electromechanical throttle via the Motronic control module. The “conversion” between accelerator pedal angle and throttle angle is performed in the Motronic control unit. Sensitivity and hence driveability in the lower speed and load range are factors here, as is even transmission across the entire pedal or throttle travel.
When the Sport Chrono button is active, a more dynamic accelerator pedal characteristic produces a more spontaneous engine response, underpinning the sporty character. This is achieved via a steeper rise for the electronic throttle characteristic by means of a shorter “conversion” between accelerator pedal and throttle angle. This means that the throttle is opened further or faster with the same accelerator pedal travel and selected Sport Chrono function (with Tiptronic S only in the manual “M” position)."
Sport also allows a more 'relaxed' PSM intervention, i.e. you can achieve about a 45 degree slip angle before it cust in to straighten you up !
I'm gonna take a high performance driving class this January or February, so I'll see how effective the PASM (without the true Sport button's bells and whistles) at the kidney-busting setting really is. Actually, at higher speeds, the PASM "sport" setting is considerably less harsh.
I find that on track use, sport is perfectly matched to the cars dynamics.
You can rotate the rear better on corner entry with the sport setting, as it allows this to happen before saving your *** if you nail it too early or too hard !
Can't wait to give it a try. Is that "sport" on the PASM only? The car certainly feels more controllable when I punch it, say, on some of the more windey parts of L.A.'s Mulholland Drive.
