P2189 Oxygen Sensing Adaptation, Idle Range, Bank 2 (RKAT2) - Above Limit
Possible fault cause
- Incorrect main charge signal
- Intake air system leaking
- Fuel pressure too low
- Volume supply of fuel pump too low
- Mechanical fault in injection valves
- PCV valve leaking
- Cap of oil filler neck leaking
- Leaks in exhaust system
- EVAP canister purge valve mechanically faulty (hangs open)
- EVAP canister purge valve output stage faults
I would start with checking cap of oil filler neck.
- PCV valve leaking
Thanks Loren- Will post updates when found.
I forgot to mention that this fault goes away and comes back again- however you can feel that the car has a rough idle- could this be a dodgy sensor?
Edited by shipships
