I need to do TSB 9112, therefore I need to remove fuse F9. Where is this located? I know that the fusebox is at the drivers feed. Is this also where F9 is located? Is so what's the logic with the alfabet?
Regards,frank
Hi Loren, thanks once again for the quick reply!
Where is D9 located? 4th row fromthe top?
Regards, frank
Yes 4th row from the top and 9th fuse from the left.
