I would like to run the DOT Michelin Sport Cup tires on my 2008 RS60 Boxster for track days. What sizes (front and rear) works best?
Well, it depends on whether you want to run 19s or 18s. Personally I would go with 18s. Cheaper tires, cheaper wheels and lower unsprung mass.
For 19" - 235/35/19 front and 265/35/19 match stock front to rear width and height exactly. Price from TireRack is $333 F and $423R for a total not shipped or mounted of $1512
For 18" there is no exact matching set for fronts and rears but you could go with 235/40/18 Front and 285/30/28 Rear. This would give you more rear tire which should make the car a little more stable in the back - good for track days, bad for autocross. A set of 4 will cost you $1248
For wheels I like the Enkei NT03-M 18x8.5 front and 18x10 rear $1582 for all 4
Or for cheap the Moda MD1 in 18 or 19" sizes for less than $800 for all 4
Also for cheap are Sport Edition Cup 4 in 18 or 19 also under $800 per set
Pricier but not outrageous are the Volk TE37 in 18 or 19 $780 to $860 each
You might also want to give Complete Custom Wheels a shout. They have lots of Porsche track wheel fitment experience and seem really sharp. Speak to John http://www.ccwheel.com 1-888-577-0144
Hope that gets you started.
Regards,
Alan
Regards,
Alan
Thanks Alan. That should give plenty to contemplate
I went to a track day recently with a number of other boxster owners. A few of them ended up with engine management faults and plumes of smoke from the exhaust as a result of pulling high G in corners. There were also some mechanics on site from one of the Porsche tuners who commented this is a common problem with the m96 engine since it is not a true dry sump and the 10 odd litres of oil that slosh about can get up into the inlet. The boxster has a greater capacity for speed into corners than the 911 so maybe they are affected more. In fact they commented that sticky tyres for a 987 are a bad idea purely becuause of this issue. The problem is cured by driving off the circuit on a normal road for a few miles after which the faults clear and the exhaust smoke disappears.
