greetings i had new rims and tires installed not long ago...stats---2000 C2.......18X8...18X10 225/40/18....265/35/18...offset 50 front and 65 rear...........my drop is 25inch in front and 25.5 in rear and it sits on cargraphic H/R.........................................should i align to gt3 specs or ?????
Edited by maci911
I would not use the GT3 specs unless you put coilovers on the car.
Did you change the suspension components when you did your conversion?
no the car came with 19's wheels originally and h/r cargraphic...i only upgraded the new rims and tires...if u look at pic the front rim,tire
Yes, if you have a stock C2 suspension then you would use stock C2 alignment - body and wheels are irrelevant.
i dont have stock suspension ...i have H/R cargraphic springs
Which makes the car lowered - by how much?
the front sits exactly at 25inches from ground to the fender and 25.5 in rear........
