I looked at the backs of the door & dash trim of the new wood kit....it had clips so I managed to pull out the aluminum pieces and installed the wood pieces (except the 2 pieces on the dash behind the steering on left side)....these pieces did not have clips like the others.
Now I need to pull out the center console (the area around the gear lever) but not sure where to start....any clues?
Two umbraco screws underneath the armrest has to be removed, then pull up the part around the gear lever.
Isak
(In wich state are the alu parts you are removing? I might be interested buying them.....)
