Aftermarket Clutch Engagement Way too High
iforged
"The engagement point of the clutch is too high" i assume that the pedal travel is too long ( engagement point is almost at the end of the pedal travel ) It's the same phenomenon as a used clutch= clutch plate thickness too thin, buy a original one.
What i exactly trying to say is that there is something wrong with the distance ( room? ) between the flywheel and the pressure plate, in fact wrong flywheel, clutch plate or pressure plate.
