Just had Major service today and was advised that front left cooling fan is not working. Told it could be either resistor or the fan itself.
Is there a way to prove either or do I just bite the bullet and go for the fan and is this easy enough to change?
Car is a 2002 C4 Cab.
Thanks for any support guys.
Grounding the relay for the fan (driverside footwell) with key on will test the entire circuit. Unplugging the fan and feeding it 12 volts will test the fan.
