I just got this warning on my car. We checked it with the Durametic and it says faulty brake sensor on the pedal. Is this common? I was reading another thread and it states to replace the entire wire harness. TIA
abs|pasm module code 4340 stop light switch
and
dme code 364 brake pedal position sensor
I just replaced the brake pedal switch, and my tech is saying the durametric won't allow him to clear the code.
Has anyone else had this problem and what did you guys do to fix it?
  Loren said:
Did you make sure the switch is properly adjusted?
Do the brake lights work?
Yes the brake lights, I just tested them today.
