Ok I know Im asking for a miracle, but....does anyone out there know if the 996 GT3 knuckle will fit on a 997 carrera???? Thanks in advance.
Do you mean lower control arm (to add camber) or wheel carrier hub?
I mean wheel carrier hub (the piece that the caliper and rotor bolt onto).
I don't think so.
The 997 uses several different hubs depending on options (C2, C2S, C4, C4S, steel brakes or PCCB).
What are you trying to do? Add larger brakes?
