Hi Forum,
I have a grinding noise coming from (what I suppose) the rear door on the driver's side. It appears while cornering and while driving over small bumps, and recently I discovered that I can reproduce the sound when I pull on the door while it is fully opened (i.e. pull the door "more" open when it is fully opened).
Did anyone experience a similar problem, if so what have you done? Is it necessary to adjust the door (if that can be done, if yes - how?), or is there a place I can lube? I'm kind of afraid of the inevitable dealer-rape, so I thought I'd ask you guys first :D
No need to say that this drives me crazy, so any help would be greatly appreciated !
Greetings from old Europe,
Alain
Oil the door hinges and apply a small amount of silicon grease on the chrome door latch to start with.
