Good Morning
Need front brake pads -- who has best pads for --- low dust and stopping ability. Don't track the car only around town -- occasional trip to the mountains -- Tail of the Dragon etc. Also who has the best price --- they are all over the place. Also anyone have a good set of used 265-35-18 rear tires?
Thanks and keep up the good site.
Chuck in Myrtle Beach, SC
Personally I like the OEM Porsche pads. They work great for the street and don't give off a lot of dust.
I get all of my parts from JPLV Porsche parts.com They have great prices and very fast shipping. Make sure you order the backing plates and shims. If you are not sure what to order send them a mail and they will tell you.
Here is the link http://www.trademotion.com/partlocator/ind...CFQpzHgod3jRJrQ[/url]
Hope this helps
Phillipj
Edited by phillipj
I have heard from several sources (PCA Tech Q&A) that OEM brake pads are best for just street use. Some track cars use PAGIDS but there are at least 4 kinds and you have to be careful that you are not getting the super race (very hard) pads. Also check the DIY section of this site and there is a list of needed parts for a brake pad replacement. Porsche requires replacing even the retainer at each and every changeout plus the other parts. Also if changing out the OEM pads with the brake warning system, you may find that aftermarket brands may require to to drill out a small hole in the pads for the sensors. There is also some great pictures in the DIY section that show just how to do it as well. Also alot of DIYs on brake pads will say to disconnect the caliper from the brake lines, but is you are careful just suspend the calipers with good wire out of the way if you are also swapping the rotors. I was also told that european rotors should not be ground, that replacement is required because of thickness and tolerances.
