Porsche 2001 996 C4 Tiptronic Coupe.
In the process of removing the Coolant Expansion tank, I inadvertently pulled out the fuel injection valve from the main engine receptacle and forgot how it looked like before I pulled it out.
My questions are:
-Is the valve secured enough in its receptacle or should it be further in (pls see pic)? (I tried pushing it as hard as I could but it won't budge).
-Will the fuel leak and catch fire if the fuel injector valve is not replaced properly?
Thanks in advance for your inputs.
I found the answer:
The fuel injector valve is secured as it is. I confirmed it after peeking through the small crevices on the opposite side of the engine in which the other 3 valves are located.
Thanks.
Edited by mtorr
