99 C2 has a problem after about 15 minutes of driving. It just shuts off and it starts after about 20 minutes. Makes getting from A to B pretty exciting. Feels like it is losing spark, any ideas??
How's the ignition switch been?
A number cars have had ignition switch failures. Have you had to wiggle the key to get the key in, out or to turn?
Other obvious things would be a loose battery cable or wires loose under the dash...
When it shuts down...does you loose all electrical supply or do the instrument still light up ? will the starter rotate ?
