I've just purchased a '98 996 and have a problem with the PCM1 unit. The unit is registering 0 satelites on reception - so,
I removed the PCM1 unit from the dash and have found two cables the cables on the back - 4 blocks plug into the unit and the FM & GPS lead.
The back of the unit has a place for the FM aerial lead but no where to plug the GPS - Is this my problem???!! or is this just a red-hearing i.e. is the gps signal connected via one of the alternative connection blocks.
Does anyone have any ideas???
Many thanks!
Alan Ross (ross_aj@hotmail.com)
Connector pin assignment, display and operator control unit
Plug A
1 - Speed signal
2 - Free
3 - Free
4 - Terminal 30
5 - Terminal 30 for windscreen antenna
6 - Free
7 - Free
8 - Terminal 31
Plug B
1 - Loudspeaker, rear right + 15 - Free
2 - Loudspeaker, rear right -
3 - Loudspeaker, front right +
4 - Loudspeaker, front right -
5 - Loudspeaker, front left +
6 - Loudspeaker, front left - 20 - CD AF, right
7 - Loudspeaker, rear left +
8 - Loudspeaker, rear left-
16 - Free
17 - Free
18 - CD AF ground
19 - CD AF, left
Note
Plug B is assigned only if no amplifier is installed.
Note Plug C consists of 3 parts.
Pins 1 to 6: yellow housing.
Pins 7 to 2: green housing.
Pins 13 to 20 : blue housing.
Pins 1 to 6 are the loudspeaker outputs to the amplifier. They are assigned only if an amplifier is installed.
Pins 7 to 12 are the control leads for the CD changer.
Pins 18 to 20 are the loudspeaker outputs of the CD changer.
Pins 7 to 20 are assigned only if a CD changer is installed.
Plug C
1 - Line out, rear left
2 - Line out, rear right
3 - AF ground
4 - Line out, front left
5 - Line out, front right
6 - Terminal 30 for amplifier
7 - Control lead for CD changer
8 - Terminal 30 for CD changer
9 - Free
10 - Data lead
11 - Clock lead
12 - Reset lead
13 - Free
14 - Free
D-Antenna lead
E-Fuse
Plug I
1 - Video signal, red
2 - Video signal, green
3 - Free
5 - Free
4 - Free
6 - Terminal 31 7 - Free 8 - Free
9 - Free 10 - Terminal 30 for navigation
11 - Terminal 58 d 12 - Free
13 - Terminal 30
14 - Video signal, blue
15 - Video signal synchronisation
16 - Video signal ground
17 - Free
18 - Free
19 - Terminal31
20 - To combination plug IIIpin 6
21 - From combination plug IIIpin 11
22 - Free 23 - Fuel consumption signal
24 - Speed signal
25 - Free
26 - Terminal 30
Plug II
1 - Diagnosis lead
2 - Terminal 15
3 - Terminal 86 s
4 - Data lead to navigation unit
5 - Free
6 - DSP (amplifier) ground
7 - Handsfree microphone ground
8 - Handset microphone 9 - Handset speaker
10 - Terminal 30, handset 11 - Free
12 - Voice output ground
13 - Voice output
14 - DSP (amplifier)
15 - Data lead from the heater / AlC unit
16 - Free
17 - Data lead from the navigation unit
18 - Free
19 - Free
20 - Handsfree microphone
21 - Handset ground
22 - Handset on-hook contact
23 - Free
24 - Free
25 - Free
26 - Free
Nav unit follows...
Connector pin assignment, navigation unit
1 - Terminal 31 2 - Terminal 30
3 - Speed signal
4 - Reverse-gear signal
5 - Data lead from the display and operator control unit
6 - Free
7 - Data lead to the display and operator control unit
8 - Video signal, red
9 - Video signal, green
10 - Video signal, blue
11 - Free 12 - Free
13 - Voice output ground
14 - Terminal 30
15 - Free
16 - Free
17 - Free
18 - Free
19 - Terminal 58 d
20 - Free
21 - Free
22 - Video signal ground
23 - Video signal synchronisation
24 - Free
25 - Free
26 - Voice output
Loren,
Thank you very much for the diagrams! - Can't seem to see which pins are for the GPS antenna, any ideas???
Thanks.
