I have a 03 996 coupe. Just purchased the vehicle. I cannot get the headlights to turn on. When the light switch is turned on (all the way right and knob pulled all the way) the small indicator bulb turns on (passenger side) but no headlights. When I pull back to utilize the high beam flash, both high beams work. I checked Row A, fuse 9,10 (15A) both not blown.
Anyone have any ideas?
Either the light switch or ignition switch....if you wiggle the key around do the lights come on?
Interesting, I wiggled the key and the small round lights came on, however the low beams did not come on. My ignition switch is loose and most liekly needs replaced. I appreciate the help!
