:welcome:
P0011 Adjustment of Inlet Camshaft in relation to Crankshaft, Bank 1 – Signal Implausible
Possible cause of fault
- Dirt in oil circuit
- Sealing strips on inlet camshaft adjuster faulty
- Oil pressure too low
- Mechanical fault in inlet camshaft adjuster
- Solenoid hydraulic valve faulty
:welcome:
hi thenks for the swift reply any ideas where i should start, i do run a garage so am mechanicly minded, but have no access to any component locations.
Check oil pressure, oil pump, pressure-regulating valve and oil type.
Could be someone put in the wrong oil - I would change it to Mobil 1 0W-40 to make sure. Clear the code and see if it comes back.
