Door panel differences
nmlss2006
A question if I may: speaking of 996 TTs, US, with the Bose sound option, are door panels the same? I.e., will a 2002 coupe door panel fit my 2004 cabrio correctly? I can't verify easily with what I have at hand and would be grateful for a pointer.
So if I were to keep my speaker/enclosure/grille I would be fine? Excellent, thanks!
Edit now that I thought about it: I can do that, right? Also, the 'speaker enclosure' is *inside* the carpeted part or is it the carpeted part itself?
Edited by nmlss
does this help?
Yes sir it does, thank you very much. And uh, I had access to that - I just didn't think. The enclosure is the resonance box that has the line marked '5' going to it, correct? On to confirm the purchase. Then I'll have to decide whether I want to do this myself (as you folks probably noticed by now, as much as I have driven 996s quite a bit, I've never worked on them, because that's completely impractical for me to do in Europe... so I'm learning. I hope).
