Anyone have any idea if I can upgrade a 997 (non-S) to 997 gt3 steel brakes?
is the hub different?
if anyone has tried this and has the necessary part numbers, please let me know.
I've done it on the Front, it will fit perfectly but you need 997 TT disk on the front. 996 GT3 Cup disk didn't fit. I have the caliper for the rear but I will need to change the handbrake jaws too.
thanks for the reply but im still confused.
I already have all the 997 gt3 parts, rotor caliper pads lines etc...
want to put it on a 997,
what is the least expensive way to make it work?
can i just buy 997 TT rotors all around? or how bout rotors from the og big reds? much easier than buying the new knuckles (wheel hub)... which is around $2000
