hey guys im stuck , i tryed to bleed to the system on the rear tail and i think i made it worse now it doesnt go up at all it used to go up crooked and the cylinder was leaking on one side i know im bleeding it wrong what is the correct step by step way to bleed the spoiler an easier way to do this .thanks for your help.
bernie
  • 2 years later...
I am currently going through this process with my 2004 996TT. The driver side ram was leaking and the spoiler would not go up causing a fault. I am trying the "Lucas Power Steering Stop Leak' to attempt a fix to the leak. Easy choise of $10 bucks versus $495 for ram or $1459 for kit. Also found a good link from UK with direction and picture of process.
http://www.911uk.com...pic.php?t=57705
Not successful - the stop leak did not work I purchased used deck lid and swapped the hydraulics - pump and both rams.
Edited by ghitchco924S
