If you are facing the motor from the rear of the car, which is cylinder # 1 , #2, #3, etc.? I have a misfire on # 5 and need to change the coil out but don't know which one is # 5??? ANy help???
Please?? A link to a schematic of the engine and foring order would be great???
George
Driver's side from rear to front of car are 1, 2 and 3. Pass side from rear to front are 4, 5 and 6. You are looking for the center cyl on the pass side. Lou
  • Like 1
Carrera firing order image - in a Boxster, the engine faces 180 degrees the other way.
So in a Carrera, 1-3 are on the drivers side and in a Boxster, 1-3 are on the passenger side.
Bank 1 is cylinders 1-3 and Bank 2 is cylinders 4-6.
  • 3 years later...
  • 10 years later...
