I have a grinding sound coming from the drivers rear wheel. I just replaced the rotors and pads (all Porsche OEM with backing plates) My guess is that it's coming from the emergency drum brake.
The handbrake seems to be fine. If I roll the car back and forth in the garage (with power off) I can hear the grinding sound.
Any advice? Difficult to access the brake? Anyone had a similar problem?
Thanks in advance
You can adjust the emergency brake with a flat screwdriver trough the lug holes, turn the adjuster approx. 2 or 3 clicks back and try again while turning on the wheel.
.. or a pebble caught between the splash shield and the brake rotor?
No it's not that Loren. It was making the same sound before I installed the new rotors and pads.
I found a link on how to do the adjustment.
Strange though because I have to pull up the handbrake lever all the way to get it to engage.
How could it be dragging if it needs to be adjusted? Could just one side be out of adjuatment?
Thank you
