Porsche Cayenne 2004 3.2
Airbag fault code 1218 from durametric
Side airbag triggering Unit
Does anyone of you had similar problem. I have reset the light but still comes up.
:welcome:
Fault code 1218
Ignition circuit, passenger's side airbag
Possible cause of fault
- Upper limit exceeded (based on resistance of passenger side airbag and wiring between airbag trigger unit and passenger side airbag)
- Lower limit not reached (based on resistance of passenger side airbag and wiring between airbag trigger unit and passenger side airbag)
- Short circuit to positive
- Short circuit to ground
- Passenger side airbag faulty
- Airbag trigger unit faulty
:welcome:
Fault code 1218
Hi Loren,
I'm back in the dealer as a tech again. This code is very common, its a bad electrical connection at the side air bag connectors under the seats, for the 04 m.y. there is a service action campaign that should be covered under warranty. He would have to call into the dealer and ask if he has any outstanding campaigns on his car.
Ciao :rolleyes:
I have drivers side airbag ignition circuit Durametric error code 1587 I tried reseting it with duramtric, but it keeps coming back. ANy Idea how to fix it ... or do I have to bring to dealer. I still have CPO.
Fault code 1587 -- Driver’s airbag ignition circuit (stage 2)
Possible cause of fault:
- Upper limit value exceeded (based on the resistance value of the driver’s airbag unit and the wiring between the airbag triggering unit and the driver’s airbag unit)
- Lower limit value not reached (based on the resistance value of the driver’s airbag unit and the wiring between the airbag triggering unit and the driver’s airbag unit)
- Short circuit to B+
- Contact unit between steering wheel and vehicle faulty
- Driver’s airbag unit faulty
- Triggering unit for airbag faulty
Not sure you really want to mess with an airbag - since you have CPO this may be a good time to use it.
