I have an 04 Turbo model with 35k miles. On the way to work on Friday my car spewed 7 qts of engine oil onto the ground in about 90 seconds. It turned out that a screw/bolt on the oil pressure regulator came loose and allowed the oil to shoot out. Luckily, no engine damage. They tightened it up and said it was good and didn't need to be replaced. I just wanted to know if this has happened to anyone else. Two dealerships said that they've never seen it before.
Matt
