I just picked up roof rails for my 05 CTT (the long ones that go from front to back) and I was wondering if anyone has mounting instructions. They look pretty straight forward, but I noticed some of the mounting clips are different. I don't want the things coming off at high speed so I thought I would ask here first.
Bob James
There is a 6 page TSB on installing the Roof Rails. Available here to Contributing Members or you can try to get your dealer to give you a copy.
TSB 2/04 6687 Roof Rail Installation Instructions -- dated Feb 25, 2004
Thanks Loren,
I tried to contribute, but It gave me an error in processing. Do you have another way?
Never mind it worked that time; now I'm a real member :renntech:
Edited by stealthn
Thanks Loren,
I'm surprised they recommend changing the locking screws, who would have thunk they are glued in?
Could I just not use locktite or another adhesive?
Thanks Loren,
That would be your option. If it were me I would use Locktite as long as the screws are not damaged at removal.
It does look like it's blue loctite, but I see their point (and disclaimer) to get new screws. I will check tomorrow to see how much, and if available the new ones are.
Could I do an article with pictures for here?
Bob
Thanks Loren,
