Does anyone know where the non-return valve (item no. 5 ) is located? It is used in the Variocam Plus system beginning 2002 for 996’s. I can’t find it as a standalone part in the parts list so I am guessing that it is integrated into the valve tappet housing or in the Variocam hydraulic actuator valve.
I think they are talking about the pressure relief valve on the oil pump housing.
Loren, I think the pressure relief valve is something else. The non-return vavle is like a check valve.
