Hello all,
Anybody have any luck with the dreaded code P0410 - secondary air injection system. This car is a 97 993. This is the code that leads to the removal of the engine, flushing of the ports and valve job. Does anybody have more information on this code, I could not find much while using the search feature. Thanks much in advance.
When I left the dealer hadn't had the problem with 97s, but on the 95-96 there is no choice but do a valve guide job. i used to keep a set of heads in stock to reduce the down time of the car. If you are the original owner contact PCNA and see if they will give you any assistance.
  • 5 weeks later...
Wow-
I have been thinking of buying a 993 [997 look alike], does that code really mean you guy's need to tear down your top end.
If you do not know much about Porsche's I think people can mistake the 997 for a 993.
I have not seen one [997] yet, but the pictures make them look similar.
