The last person to work on my cars transmission replaced the clutch fork pin 180 deg out of place so the threaded end is hidden. Anybody tackle this before? The mechanic says the engine might have to come out to do the clutch since he can't remove the clutch fork pin. Any ideas?
What do you mean with clutch fork pin? I suppose the axle, if it is the case and the bearing with the hole in the middle is placed as it should ( the side where the rubber plug is ), than weld a bolt on the axle, through the axle and pull out.
Renew the axle and the bearing.
