Can you be more specific?
As I recall speed is determined from the four ABS/PSM sensors at each wheel.
My odometer is not working and I am thinking it maybe the speed sensor. I am not sure at this point and trying to diagnose the problem.
As I said there is a sensor on each wheel.
You will likely need a PIWIS tester to find out if the fault is in your instrument cluster or somewhere else.
