  • 2 months later...
Can someone post the filling procedure for Cayenne S with tiptronic tranny? thanks...i can't find it anywhere.
dear mitymikec you need porsche piwis tester and go to control unit test go to tiptronic test than actual value in atual value you select tiptronic temp the temp should be 30c to 40c in thas temp you can fill the trans with ATF in the lower side of trans sump mabe 14mm plug for oil filing thanks
abdul ghaffar
  • 6 months later...
