I"m pulling the shift cables off the linkage to see if my bind is the cables or something else. Best I can tell from Bentley is one should just shove two screw drivers between the bracket arm (ball) and the socket arm. But I'm not having any luck but feel I'm about to bend the ball bracket arm.
I also have a forked screw driver that it's in between the assmeble (ball/socket) with a small bend not unlike a mini crowbar. No dice either.
Is there a special tool or puller (that would not fit in that area anyways) or do you just keep bending and cussing until something gives?
This seems to be the simplest task that just will not give on any of the linkage ball and sockets.
Shawn
