Has anybody done this?
Invicto, were you able to do it without removing the engine? My mechanic found a leak at the intake distributor rubber sleeves. Apparently they are loose and are leaking under load.
Thanks in advance.
R
Edited by RickyBobby
If the rubber sleeves are at fault you can remove them without lowering the engine. You just need to remove the throttle body mount.
