2000 996 Cab C2
Can someone guide me to stops to remove the center surround? Attached is a stock pic for reference.
Thank you!
Phillipj
Just gentle pull of, starting on the left or right bottom corner.
2000 996 Cab C2
Thank you!
Phillipj
Phillip,
No screws, just a "snap-in" piece. As RFM stated, start in lower left corner and gently pry out. I use a plastic "putty" knife to pry to begin as it won't scratch either the surround or dash if you're careful.
Good Luck!! demosan :cheers:
