Put some new rear tires on my car the other day and I noticed that at highway speeds when I accelerate my car seems to pull to slightly to the left and when I deaccelerate it goes back in line. It doesn't happen on every road but on I95 it occurs most. Is this a natural phenomenon do to the torque generated by the drive wheel (no LSD)? Could it be the new rear tires (Potenza 050A's) fyi the fronts are the same but are N0's and the new rears are N-1's. One of the technical guys at the tire rack said there are two different compunds between the N0 and N1 tires and said they should have only recommended N0's to match the fronts as the N1's will cause problems if mixed with N0's. Tire Rack is sending me a set of N0's to swap into.
Appreciate any feedback.
Edited by 500
If you have got no problems before the tire change, a good chance that the new ones are the culprit than.
Never really noticed it before but I also wasn't looking .
