How do I get at my generator to remove it? The voltage regulator seems to have packed up. The volts drop back from 14 to under 12, once the engine has been running for one minute and the battery went flat. Can it be repaired?
Do a search, alternator removal is discussed here many times ( 996 and 986 forum ). In most cases, the alternator can be repaired.
