The drivers side Xenon low-beam on my '03 996 was working intermittently but recently failed. I replaced the bulb (Ds2) and checked the fuses but not working at all. Any suggestions ?
There will be a front end control module to drive the Xenon lights. These usually have a local earth point as the the circuits are switched to ground via the module. You could try checking the module its connections and local ground points , otherwise it could be a simple matter of the ballst / igniter unit failing. Swapping the igniter from one side to another should prove this point.
