Hi, my reverse lights and park assist have just stopped working, i checked ALL the fuses as none are listed on the checksheet in the fusebox, so i'm guessing its either a relay or the microswitch on the gearstick.
Anybody have any ideas as to the location of the relay (if there is one).
Start by checking fuses.
B5 is the backup lights and B10 is the parking assistant.
If both are fine then you likely have a bad backup light switch (on the transmission).
