I am trying to access my 5 speed linkage at the tranny to determine if my cables are at fault for stiff shifts.
To get access to the linkage on the passenger side there is a plate in the way. Bentley (34-3) defines this as the chassis reinforcement plate. I thought this was nothing more then a skid plate, but this name makes me think it does some supporting I may not see.
Regardless can I remove this plate with what appears to be 8 bolts with 4 that attach at the aluminum diagonal braces w/o having to remove the braces? I am hoping those two bolts when removed will allow the plate to slide out of the way.C
Can someone confirm this before I start. I have the car on ramps at home since my lift at work is not available. There is not much room if I get thrown a curve to correct anything. I just want to make sure that plate is not supporting any weight.
It's amazing two see what two winters in Ohio can do to a clean car from Florida. I couldn't get the salt off it last year and it has paid the toll! I do not even drive this car in the winter unless there is an emergency (and there way) and you can see the salt deposits everywhere!
