Hello all!!
Quick question in regaurds to the strut bearings. I need to replace the front bearings on my 01 Boxster S due to a annoying binding sound evey time I turn the wheel. Can I just buy the bearings for $20 (x2 for both sides) at Sunset, or should i replace the the strut mounts on both sides as well (mounts $52 a piece)? This has to due with the preventative maintenace... rather now than later. How often do the mounts fail, and is it worth the money?
You guys are the best!
BBSO
Edited by Loren
reduced font size
Replace the mounts as well, it's not that expensive and reduce other noises.
