Does any body know where is the plug for the cam aucator for the bank 2 is. I keep getting the p1529 error even the car is at idle .. when I tried to clear the code with only the ignition on and the engine not running., the code can be cleared. However when I start the engine the code would come back right away without even revving it at all.
I want to see if the plug has somehow came off or the wires are bad..
thanks
Connector actuator bank 1 ( driver side ) is located on the engine bloc at cyl. # 3 in the gearbox area.
Connector actuator bank 2 ( pass. side ) is located on the engine bloc at cyl. # 4 rear side of the car - exhaust area.
